P0733 & P0734 trans codes
2001 Disco 2. The truck isn't shifting into 4th gear. I pulled these codes out of it(some might be old codes) P0733 3rd gear ratio, P0734 4th gear ratio, P0171 bank 1 lean, P0174 Bank 2 lean, P0300 misfire and P0305 miss on cyl. 5. The truck is running fine and the only thing I notice is the truckisn't up shifting to4th gear. I'm really only worried about the trans codes. I'm a GM mechanic and I'm totally lost with Land Rover. I didn't find any TSB on the Trans codes but my question is- I didn't know if the 733 and 734 codes coming on together would come from only one root problem. Anyoneran into this before??Any thoughts???
rishmoca
01-10-2008 12:05 PM
