Sponsored by: CARiD
P0733 & P0734 trans codes
Old Nov 21, 2008 | 02:38 PM
Lupdiesel's Avatar
Default P0733 & P0734 trans codes
2001 Disco 2. The truck isn't shifting into 4th gear. I pulled these codes out of it(some might be old codes) P0733 3rd gear ratio, P0734 4th gear ratio, P0171 bank 1 lean, P0174 Bank 2 lean, P0300 misfire and P0305 miss on cyl. 5. The truck is running fine and the only thing I notice is the truckisn't up shifting to4th gear. I'm really only worried about the trans codes. I'm a GM mechanic and I'm totally lost with Land Rover. I didn't find any TSB on the Trans codes but my question is- I didn't know if the 733 and 734 codes coming on together would come from only one root problem. Anyoneran into this before??Any thoughts???
Old Nov 21, 2008 | 07:38 PM
lrobin3w's Avatar
Default RE: P0733 & P0734 trans codes
MAFS can cause these faults.
Old Nov 22, 2008 | 09:18 AM
Start with a new MAF, that will clear your codes and the tranny should be fine again.
By the way, are you running a K&N air filter, if so get rid of it, it is the biggest cause for MAF failures.
Old Nov 23, 2008 | 03:01 PM
Lupdiesel's Avatar
Is there any way to test the MAF sensor or should I just replace it? On the GM cars, I would drive the car with the MAF unplugged and If the problem went away I replaced it. I guess I'll give that a shot. Thanks for your HELP!!!!Kyle
Old Nov 23, 2008 | 06:14 PM
You aren't driving a GM, better get used to how our Rovers play with us.
Call Tony, at 650-365-4145, for one of the better MAF prices, install it and clear your codes.
richo888
Jul 19, 2013 09:40 AM
Belthasar
Jun 15, 2011 08:30 AM
msilverman239
Dec 16, 2010 12:51 PM
utunes
Mar 14, 2008 08:02 PM
