Sponsored by: CARiD
Passenger door wont open
Old Dec 2, 2005 | 05:27 PM
r1pilot's Avatar
Default Passenger door wont open
2000 Range Rover Passenger door will not open from the inside or outside. Vehicle just went out of waranty. It seems mighty strange/or intelligent how lots of things like to go wrong at 100,000 miles. Anyway, possible problems and how much to fix at range rover dealer or can i do it myself? Thanks
Old Feb 10, 2006 | 03:19 AM
karenandharry's Avatar
3rd Gear
Default RE: Passenger door wont open
u have to take the door panel off and replace the hinge. they brake easily. there is no other way
Old May 2, 2006 | 11:22 AM
freemanesq's Avatar
5th Gear
I know this is a late entry for this item but I wanted the response to be in the database.
It depends on what kind of "won't open" you're talking about. My 95 just wore out the over engineered locking mechanism. To open the door you had to put in the key and turn it all the way to the left, hold it, and then pull the door hand (or hold the manual door lock all the way up then pull if inside). I replaced all the interior lock linkage and items that pivot and that fixed it.
R.
pgk
Feb 14, 2012 10:35 AM
jwage
Nov 12, 2011 07:59 PM
tnhotrod
Jun 28, 2010 06:54 PM
Prowler9876
Feb 22, 2010 08:31 AM
