Sponsored by: CARiD
please help front windows wont go up
Old Oct 25, 2014 | 07:10 AM
junkbilly's Avatar
5th Gear
Default please help front windows wont go up
could someone please help me we have a 1999 land rover range rover 4.6 HSE and the front windows will not go up the message on the dash says windows not set the rear windows work and sun roof works just the front windows wont go up please help me before it decides to rain thanks
Old Oct 25, 2014 | 08:37 AM
abran's Avatar
Windows not set is a message you get when the battery has been disconnected or jumped.
The BECM wants to know the exact position of the windows when that are all the way down and all the way up. I'm still not sure that is why they won't roll up though.
Make sure you have a good battery. Turn the ignition to the second position.
Then start with one window and hold the button in the down position for a few seconds, then push it in the up position(it should now roll up) then hold at max closed for a few seconds. The dash should now indicate window set.
Do that for the windows and the sunroof of you are getting those messages.
Here is a link for more info:
Range Rover Synchronisation Guide
Good luck
Old Oct 28, 2014 | 09:36 AM
agthird's Avatar
check the interior fuse block.
Old Nov 3, 2014 | 12:18 PM
mattmo78's Avatar
Could be a bad motor or window regulator also. You'll have to pull the door panel off to check those.
keithd21
Aug 2, 2012 07:14 PM
losbadgt
May 18, 2008 07:04 PM
bhorwhat
Oct 16, 2007 10:14 AM
dmm698
Aug 28, 2007 06:37 AM
