Sponsored by: CARiD
please help I have no idea what is wrong
Old Jun 20, 2014 | 10:15 PM
Josh Matthew's Avatar
7th Gear
Default please help I have no idea what is wrong
Hi,
I'm having some major problems that have kept my land rover discovery II from being drivable.
I can't remember all the codes but it is misfiring on all even cylinders and is throwing a p1300 code and oxygen sensor codes
I have pretty much replaced everything already, maf sensor included.
I drove it through some pretty heavy water at the river, it ran fine until I got home parked it and let it sit for 2 hours then it started misfiring the misfire has got worse and worse probably due to the fuel mixture not being correct, I replaced plugs wires, up stream oxygen sensors, mass air flow sensor, fuel pump which includes the fuel pressure regulator and filter,the camshaft sensor, both cool packs, and tested for spark on all cylinders, tested the compression on all cylinders, and finally pulled the exhaust at the manifold to make sure there wasn't a clogged.
I'm running out of ideas please help.
Old Jun 20, 2014 | 11:15 PM
Read all codes or get them read for free at most parts stores. Write down numbers, not what scanner text says, it can vary. Post back or look up in the RAVE shop manual.
The crank position sensor is one you have not mentioned, it controls the spark timing.
One thing that can happen with "wading" is that water can get in connectors, and then set up corrosion. Even dried out there may be "gunk" between pins. Worth pulling them apart for inspection. Go back with dielectric spray.
Old Jun 25, 2014 | 12:28 PM
7th Gear
Default crankshaft position sensor
I replaced the crankshaft position sensor now and it wasn't a problem, the codes on a normal code reader have been completely useless, I've decided to have a diagnostic ran on it, I will post what the issue was after I fix it.
Old Jun 25, 2014 | 02:06 PM
dusty1's Avatar
codes on all even #s ..... o2 sensor.....
are you using coolant?
Old Jun 25, 2014 | 04:01 PM
MonteroMan's Avatar
Default How deep the water?
Originally Posted by Josh Matthew
Hi,
Josh, how deep was that water?
I hope this is not your problem: In a moment of silliness I drove my Defender Tdi (side air intake) through a little brook in flood once, just 200 yards away from my home instead of waiting for the flash flood to subside. I waded through the water first and it was almost at top of the wheels. The rapid flow of the water waved up against the side of the vehicle and some entered the intake.
As I stopped at my house the engine suddenly banged, belched white smoke and failed. Starting resulted in very heavy uneven ignition.
It turned out a little water had saturated the air filter, gone past and ingressed the inlet manifold into one cylinder which was just doing the intake stroke at the time. Total hydraulic lock and bent conrod and stretched cylinder head bolts. She would start OK, but the two cylinders in the downward stroke received the water.
Good luck.
Old Feb 9, 2016 | 08:31 PM
Huseyin Ursel's Avatar
7th Gear
hey guys any one can help me with my 2001 disco 2? some one replaced the lover intake gasket after that it blow 2 ignition coil now i just notice car wont go over 2k rpm some times engime light flashing can somebody help me please please codes are i am getting is p0130 0135 0155 0102 0340
Old Feb 9, 2016 | 08:54 PM
Joemamma1954's Avatar
P0130=Oxygen Sensor Cycle Fault bank 1
P0135=O2 sensor heater circuit malfunction bank 1
P0155=O2 sensor heater circuit malfunction bank 2
P0102=Mass Air flow sensor
P0340=Camshaft sensor malfunction
Looks like someone did not plug back in some sensors
collin Barrows
Audio/Visual Electronics
Aug 22, 2011 10:22 PM
tornado_735
Sep 25, 2010 08:42 PM
elboy0712
May 10, 2010 08:22 PM
hilltoppersx
Off Topic
Feb 4, 2010 03:10 PM
myall200
Nov 23, 2008 10:39 PM
