Sponsored by: CARiD
Please Identify this part
Old Jul 10, 2014 | 02:22 PM
1999SE40's Avatar
Default Please Identify this part
I found this part on a Range Rover 1999 it is soldered into the AC pressure switches wiring ? Please Go to this .pdf http://www.gomog.com/allmorgan/GEMS/GEMSbyPoole.pdf
Photo on page 54 shows a fuel filter with a 250 ohm resistor with a heat-sink mounted with 2 small flat head screws. It is in the bottom left corner of the photo.
My resistor is soldered to the AC pressure switch wire, but mounted behind the US driver side head light next to what looks like the yellow air bag sensor ? It is in the - negative side of the electric system (ground)
If you know what this is and where the wire should go please let me know.
MPDano
May 23, 2015 06:49 PM
DonRW2007
Jan 6, 2014 09:19 AM
ngarover
Jan 2, 2013 08:43 AM
Jake Mays
May 3, 2012 09:40 PM
batiscan
Jun 19, 2010 11:16 AM
