power steering pump trouble
You need to open the bleed screw on top of the PS box. Turning the wheel back and forth only makes it worse. If the fluid is already foamed, allow to sit overnight.
PS Bleed procedure; Top off reservoir with ATF. Remove cap and open the bleed screw (7/16" nipple) on top of the PS box. Wait until you see ATF fluid coming out. Tighten screw and start engine for a few seconds, then shut off. Top off fluid, open bleeder again until clear ATF comes out. Done. Repeat one or two times if necessary.
Did it work ?
Did it work ?
johnnyjohnny
09-26-2019 09:37 PM
joshjellel
02-16-2015 10:53 AM
losinov
03-21-2011 08:57 PM
