Sponsored by: CARiD
power steering pump trouble
Old Dec 28, 2005 | 07:06 PM
brokendisco1's Avatar
Default power steering pump trouble
I can't seem to be able to bleed out all the air in my pump, it keeps squealing and foaming up
Please help!! 95 DiscoI
Old Dec 29, 2005 | 08:21 AM
Nux's Avatar
Nux
Default RE: power steering pump trouble
Are you using the correct (viscosity/grade) approved fluid? From experience, this usually makes a difference in various european pump designs.
Old Jan 1, 2006 | 11:24 PM
Bait's Avatar
You need to open the bleed screw on top of the PS box. Turning the wheel back and forth only makes it worse. If the fluid is already foamed, allow to sit overnight.
PS Bleed procedure; Top off reservoir with ATF. Remove cap and open the bleed screw (7/16" nipple) on top of the PS box. Wait until you see ATF fluid coming out. Tighten screw and start engine for a few seconds, then shut off. Top off fluid, open bleeder again until clear ATF comes out. Done. Repeat one or two times if necessary.
Did it work ?
Old Jan 3, 2006 | 05:39 AM
mikemeyer0's Avatar
Use ATF, did you mix it with something else or re-fill W/O ATF?
johnnyjohnny
Sep 26, 2019 09:37 PM
joshjellel
Feb 16, 2015 10:53 AM
Matt_Attack352
Jan 13, 2014 09:55 AM
losinov
Mar 21, 2011 08:57 PM
caleb
Nov 30, 2009 09:46 PM
