Problem unlocking !
Has this fob ever worked ?
I just got a fob for mine and of course it has to be programmed to the truck before it will work...
If fob has been known to work.. Then.
1. Bad new battery
2. Battery installed upside down.
3. Fob is actually bad or no longer programmed to the truck.
4. You messed up one of the buttons when you had it apart..
You might take it apart and pull the pcboard out of the shell and check the switches to make sure they are working correctly.. You should be able to hear them click...
John
1. Bad new battery
John
meltdowndave
04-19-2008 09:50 PM
