Sponsored by: CARiD
Problem unlocking !
Old Dec 31, 2012 | 11:30 AM
Bobbybhoy67's Avatar
6th Gear
Default Problem unlocking !
Can anyone tell me why even with a new battery in the fob will my disco 2003 not unlock , the internal alarm goes off if I just unlock using the key . Please help .
Old Dec 31, 2012 | 12:04 PM
Try locking and unlocking the door, with the key, 3 times in a row and see if that resets your alarm.
Old Dec 31, 2012 | 12:16 PM
6th Gear
Mike , I just tried that with no luck. The red light comes on when pressing the fob
Old Dec 31, 2012 | 01:28 PM
JPSpen's Avatar
Has this fob ever worked ?
I just got a fob for mine and of course it has to be programmed to the truck before it will work...
If fob has been known to work.. Then.
1. Bad new battery
2. Battery installed upside down.
3. Fob is actually bad or no longer programmed to the truck.
4. You messed up one of the buttons when you had it apart..
You might take it apart and pull the pcboard out of the shell and check the switches to make sure they are working correctly.. You should be able to hear them click...
John
Old Dec 31, 2012 | 01:42 PM
6th Gear
Thanks John , will work through the options tomorrow . Much appreciated
6th Gear
Meant to say , the fob was working ok .
DannyMcF
Jun 6, 2012 10:53 AM
gamekakfan
Aug 17, 2009 06:18 PM
Brad S1
Apr 21, 2008 04:33 PM
meltdowndave
Apr 19, 2008 09:50 PM
PhasersSetToKill
Dec 15, 2007 12:11 PM
