Sponsored by: CARiD
radio code
Old Jun 12, 2021 | 09:16 AM
mwhorne's Avatar
Default radio code
Hi there. I have a defender 90 and put in another Land rover radio. I have the code, but got new battery and typed in the wrong code by accident. Now it just shows the wrong code and I know there is a way to reset to be able to put in code again. But can't seem to figure it out..... HELP.. Thanks.
Old Jun 13, 2021 | 11:16 PM
Harvlr's Avatar
On my P38 if you ignore it for something like 20 or thirty minutes it will let you put in the correct code.
Old Jun 14, 2021 | 09:43 AM
WaltNYC's Avatar
In a D1 (very similar to D90) there seems to be a requirement that you have the key in pos II for 90+ minutes (the truck can be running or not but Pos II is essential). After that the code should work.
Old Jun 20, 2021 | 11:51 AM
disco96sd's Avatar
i am pretty sure if you just pull the battery negative terminal connection again it will go back to code and you can re-enter
larry99discoI
Mar 6, 2009 10:44 PM
Bob2003Discovery
Nov 1, 2008 01:44 AM
discoxd
Oct 17, 2008 11:14 PM
sreuro
Audio/Visual Electronics
Jan 5, 2007 07:16 PM
yoeman
Jul 12, 2006 12:55 AM
