Sponsored by: CARiD
Rear chunck replacement
Old Aug 2, 2011 | 06:29 AM
tandy807's Avatar
5th Gear
Red face Rear chunck replacement
Newbe here i replace the rear chunck in a d1 1996 yesterday drove well but made a squiking noise and then the rear end got hot. Is there a special way to install chunck and drive shaft. or could it be barrings in rear end. Help....
Old Aug 2, 2011 | 07:43 AM
Don't know what you are talking about, what is a chunck?
Old Aug 2, 2011 | 10:03 AM
Gator Ritt's Avatar
Maybe he miss typed. Did you mean CHUNK?
Old Aug 2, 2011 | 10:17 AM
yloDiscoII's Avatar
Is that another slang term for the diff?
....or Chunk from the Goonies?
Old Aug 2, 2011 | 11:38 AM
tandy807's Avatar
5th Gear
told you i was new its chunk. pinion and gears... is there a way to adjust so the shaft lines up perfect.. thx jt
Old Aug 2, 2011 | 11:39 AM
tandy807's Avatar
5th Gear
that is rear end or rear diff if you like, Im simple or less knoledgeable..
Old Aug 2, 2011 | 03:21 PM
Banzai Jimmy's Avatar
What exactly on the rear end got hot? The housing, the chunk, the rims, the brakes? And how "hot" is hot? The gear oil is going to warm up quite a bit from driving. If it left a blister on your skin, then that's too hot. If water boils off immediately, that's too hot. If its good-n-warm to the touch, that's OK.
As far as the squeaking noise goes... when was the last time you greased the u-joint(s) and slip yoke in the rear driveshaft?
Old Aug 3, 2011 | 11:20 AM
tandy807's Avatar
5th Gear
the actual rearend was very hot and where the drive shaft goes into the rearend was smoking it was so hot. This is what has happened and where we are now. I got the vehicle from a family member who had sold on time and didnt get paid. so i went and got the truck. I got it running and first drive the part that goes in the rearend that bolts to the pinion or the gear broke. so i ordered a rear chunk off ebay from monte rovers. we installed and drive it and thats when it got hot. and it was also making a low squeal while driving. truck runs great but need other help. thx for any info.
bennyb43
Nov 28, 2015 04:01 PM
bcolins
Jun 22, 2013 08:55 PM
Tanrover
Nov 19, 2006 03:36 PM
echoes_and_fractals
Aug 27, 2006 11:11 AM
NHxj4x4
Jun 4, 2006 12:00 AM
