Rear Windows blowing fuses on DII
my 30 amp fuse on the rear windows blows as soon as the ignition is turned on. this happens whether the center console switch to over ride the rear windows is on or off.
i'm about to go digging in the RAVE to trace out the power flow so i can start pinning it down. thought i'd post this to see if anybody had experience to point me in the right direction.
thanks
jon
thanks
jon
alright, i've got it down to the gray and white wire that runs from the center console switch to the rear switch. it is grounded.
i've checked to most obvious place, the door hinge and all looks fine.
where does the wiring harness go from the door? up into the overhead or down along the ground to the center console?
any help is appreciated so i can get this thing working again.
jon
jon
