Sponsored by: CARiD
Removing a destroyed head bolt -- any suggestions?
Old Apr 6, 2016 | 08:20 PM
mollusc's Avatar
Default Removing a destroyed head bolt -- any suggestions?
1999 D2, but that's largely irrelevant.
The flats on one of my head bolts have rounded off, so it's at full torque and I can't loosen it. Of course it's one of the bolts at the bottom of a valley, so I can't get a grinder or Dremel down there. I have the other bolts still torqued down to try and reduce the tension on it, but I'm not having any luck getting it to move.
I have drilled into the center of the bolt but I don't want to run the risk of going astray and damaging the head. I don't have any faith that an E-Z Out will be able to handle the necessary torque. Does anyone have any suggestions?
Old Apr 7, 2016 | 06:06 AM
drowssap's Avatar
Have you try a 5/8 12 point socket?
Old Apr 7, 2016 | 06:39 AM
mollusc's Avatar
Of course. Two different ones. And a 12-point 16mm socket along with a regular 6-point. Two of them split. And there's not enough head left to be able to get a socket onto it any more.
Old Apr 8, 2016 | 09:14 AM
acamato's Avatar
Craftsman makes a damages bolt/nut remover. You hammer it on the bolt head. It will cut into the damaged head, and continue to dig in as you apply torque.
Craftsman.com
Old Apr 8, 2016 | 10:58 AM
mollusc's Avatar
Hmmm. I'll take a look at those. There's almost nothing left of the head though. I'm at the point where I think I'll just have to use a pinpoint grinder on my Dremel to chew away enough of the head that it collapses.
Old Apr 9, 2016 | 12:37 PM
BritishautoworksSD's Avatar
https://www.jbtoolsales.com/irwin-53...N1fxoCGtvw_wcB
You need something like these. I have some from Snap-on and they work great
Old Apr 9, 2016 | 12:41 PM
Paul Grant's Avatar
I've had great success with those sockets.
Worst comes to worst, get your self a nice set of cobalt drill bits. Start small and keep drilling until the bolt head comes off.
Old Apr 15, 2016 | 07:25 PM
mollusc's Avatar
Well, I managed to get the bolt out, after much careful grinding and drilling and aiming with a narrow cold chisel.
The two sockets in the background are the ones that split when I was first trying to remove it, when the bolt was still mostly intact.
Damage to the head itself is minimal, thankfully.
unimoged
Jan 28, 2016 07:10 PM
focusontheworld
Oct 21, 2012 01:00 AM
vandal996
Jan 12, 2011 12:43 PM
bikeG976
Jan 28, 2010 01:38 PM
EVN137
Jan 7, 2009 04:37 PM
