Replaced head gasket now radiator problem?
Hi there, I have a 2000' land rover discovery with 87,000 miles on it. It was having some problems overheating & I took it in to a local foreign auto shop. they said the problem was the head gaskets it ended up costing me a whopping 1,700! It's been about a month since they did the work & it started having the same EXACT problems again. The problems are as follows; first I hear a swishing sound behind the passenger side dash when I accelerate, then the heater isn't working well, then it overheats & needs coolant added. I took it into the same shop thinking its possible they didn't get the head gaskets right the first time...they just called & said its a leaky radiator!? Is it me or does this sound like I'm being ripped off?
Might want a phone quote from a radiator shop. A pressure test of the cooling system can show where the leaks are. Get a new thermostat when you do the radiator. You have an option for a 180F one in addition to the stock one.
When you say overheating, what point on the gauge did the pointer get to? Red light come on?
flanker6
01-15-2013 01:15 AM
0304Disco
03-22-2011 10:32 AM
