Sponsored by: CARiD
Replaced head gasket now radiator problem?
Old Mar 27, 2013 | 05:43 PM
Sdavis's Avatar
4wd High
Default Replaced head gasket now radiator problem?
Hi there, I have a 2000' land rover discovery with 87,000 miles on it. It was having some problems overheating & I took it in to a local foreign auto shop. they said the problem was the head gaskets it ended up costing me a whopping 1,700! It's been about a month since they did the work & it started having the same EXACT problems again. The problems are as follows; first I hear a swishing sound behind the passenger side dash when I accelerate, then the heater isn't working well, then it overheats & needs coolant added. I took it into the same shop thinking its possible they didn't get the head gaskets right the first time...they just called & said its a leaky radiator!? Is it me or does this sound like I'm being ripped off?
Old Mar 27, 2013 | 07:55 PM
You could be getting ripped off, is there a puddle of coolant in your driveway?
Continue to run it low on coolant and you will be buying a whole new engine for $6000.
Old Mar 28, 2013 | 12:34 AM
Might want a phone quote from a radiator shop. A pressure test of the cooling system can show where the leaks are. Get a new thermostat when you do the radiator. You have an option for a 180F one in addition to the stock one.
When you say overheating, what point on the gauge did the pointer get to? Red light come on?
Old Mar 28, 2013 | 10:08 AM
Sdavis's Avatar
4wd High
No puddle, it looks like its been slowly leaking coolant from the overflow hose. When it overheated it never got to the red & the light didn't come on either.
dtunni
Aug 15, 2013 02:33 PM
Sdavis
Mar 29, 2013 04:00 PM
flanker6
Jan 15, 2013 01:15 AM
ctk111
Nov 20, 2012 02:23 PM
0304Disco
Mar 22, 2011 10:32 AM
