Sponsored by: CARiD
SAI Pump fan removal
Old Aug 29, 2017 | 04:15 PM
ivanwood's Avatar
Default SAI Pump fan removal
I was continually getting SAI codes so I removed the blower and found it was seized. I drilled out the rivets and removed the cover over the fan but I am not sure if the circular boss holding the fan is a press fit or screwed on, as it is not a regular nut?
Any help would be appreciated as I don't want to destroy it trying to get it off.
Old Aug 29, 2017 | 08:43 PM
JUKE179r's Avatar
I somewhat broke down my SAI pump to that level and it didn't work the same afterwards.
But this SAI rebuild info might help you... https://www.bimmerforums.com/forum/s...d-Rebuild-Info
Old Sep 2, 2017 | 09:57 AM
ivanwood's Avatar
Originally Posted by JUKE179r
I haven't broke down my SAI pump to that level yet.
Thanks for the note but unfortunately I could not access the site you gave me.
I did manage to pull of the fan using a small bearing puller with a bolt down the hole in the center of the boss. took a bit of tension and a couple of taps with a hammer before it came loose. Was able to pull the bearing off the motor shaft and it was totally seized so I guess it has been like that for some time. Got a new one for $11 reassemble the unit and at least the SAI pump now runs beautifully. I replaced the hollow rivets with brass mushroom headed bolts and thin nuts with a dab of Loctite just to be sure. Next I discovery was that there was oil in the vacuum canister that bolted on the top of the SAI bracket so I guess the is a leak somewhere in the system!!!!
Thanks
gatorm
Aug 11, 2017 04:04 AM
Hephaestus
Feb 28, 2017 07:58 PM
FyrRover
Feb 8, 2016 05:18 AM
roverbob
Sep 2, 2012 08:34 PM
uh60driver
Apr 2, 2012 11:22 PM
