Sponsored by: CARiD
Serious steering play
Old Aug 25, 2008 | 07:17 PM
roverme's Avatar
Default Serious steering play
I just purchased a 1988 Range Rover Classic. Silly me, purchased the truck sight, unseen. I just drove it for the first time today and noticed that there is a good amount of play in the steering and it "drifts". Any idea's. I owed a 93 LWB but never had this issue with my truck. Any help will be appreciated.
Thanks!
Kath
Old Apr 8, 2009 | 08:51 PM
cold_surfer's Avatar
Dude -- check the tightness of the big bolt under the steering box. it's a 1-5/16" nut and you might need a 3/4" drive or 3/4-1/2 adapter. You will need to BEND the washer flat, tighten, and re-bend it. check manual for torque setting.
This is a dangerous problem that could result in loss of steering if it loosens and falls off !!! Don't get pulled over for DUI checks because of dangerous wandering !!!!
Old Apr 12, 2009 | 12:02 AM
oldrovertech's Avatar
not only that be very carefull of the "magic" spot, if you over torque it to get a really nice feel you will wear out your worm gear in no time flat then you will have to replace your box all together, if that isnt the case already
Old Apr 18, 2009 | 07:02 PM
lrobin3w's Avatar
I would insect the front end for any loose parts, tie rod ends, swivel bearings, trailing arm bushings, etc. If all is ok, you can adjust some of the play out of the steering gearbox.
Old Apr 19, 2009 | 10:07 AM
Start with the swivel joints and cover everything steering and or bushing related, no telling what you find.
Vinndego
Jan 6, 2014 11:14 AM
xmarksit
Nov 26, 2013 08:37 AM
tom_meeks@yahoo.com
Oct 12, 2007 09:53 AM
countyrover
Oct 28, 2005 09:39 AM
Evian
Aug 18, 2005 11:34 PM
