Sponsored by: CARiD
Sound coming from the transmission
Old Jul 1, 2010 | 07:51 AM
richief556's Avatar
Default Sound coming from the transmission
When I slightly press down on the gas pedal I can hear a slight hum/light grinding noise coming from directly below me. Anyone ever ran into this problem. Whatever it is, it doesn't sound right. Help is much appreciated.
Old Jul 2, 2010 | 05:59 AM
Rovin4life's Avatar
exhaust shield loose or something else loose.
Old Jul 2, 2010 | 09:17 AM
richief556's Avatar
hmmmm, i didnt think of that. I'll get under there tonight and see if anythings loose. thx for the tip!
Old Jul 2, 2010 | 09:45 AM
Pat that or your front drive shaft failing, you will need to be a lot more specific. Have you ever rebuilt or replaced the front drive shaft?
Old Jul 4, 2010 | 09:39 AM
richief556's Avatar
i've purchased the U joint, i just haven't had the chance to install it. specific in what way? once i put in D(rive) i slighty push down on the gas pedal and get a grinding noise. it goes away once i go over 15 mph.
Old Jul 6, 2010 | 09:39 AM
richief556's Avatar
so i managed to get a look under the truck this weekend and noticed that the heat shield weld managed to come loose and I need to get it welded back in place. so now that i know where the grinding noise (or vibration noise) is coming from, ironically the Service Engine light just came on. I don't know if it has anything to do with the heat shield but I got P0150 and a P0174 reading. It can't be the 02 sensors because I just replaced all 4 about 5 months ago. Any suggestions are greatly appreciated.
Durfee
Jan 13, 2019 08:29 AM
COOTER-GUY
Nov 19, 2010 06:27 PM
roverboy
Jan 27, 2009 06:37 PM
discoken
Mar 10, 2008 06:32 AM
