SRS ABS AND BAT LIGHT
You are fighting a low battery/voltage problem.
I would suggest you go have a load test done to verify wether it is the battery or alternator.
Once it is cleared up, you will then have to have someone with the appropriate scanner clear your fault code so the warning lights will go on.
Mike
Mike
marlymarl
May 28, 2011 10:34 PM
gamecockdisco
Jul 12, 2010 08:34 AM
