Sponsored by: CARiD
SRS ABS AND BAT LIGHT
Old Dec 11, 2006 | 03:01 PM
RJADM2000's Avatar
Default SRS ABS AND BAT LIGHT
ALL LIGHTS CAME ON CHANGED BATTERY AFTER TWO DAYS IT ALL STARTED UP TAC AND SPEED GOING CRAZY
Old Dec 11, 2006 | 06:59 PM
Default RE: SRS ABS AND BAT LIGHT
You are fighting a low battery/voltage problem.
I would suggest you go have a load test done to verify wether it is the battery or alternator.
Once it is cleared up, you will then have to have someone with the appropriate scanner clear your fault code so the warning lights will go on.
Mike
khuds308
Feb 26, 2018 03:22 PM
bcbp
Jul 31, 2012 12:42 PM
marlymarl
May 28, 2011 10:34 PM
gamecockdisco
Jul 12, 2010 08:34 AM
red rover 99
Jun 22, 2007 01:30 AM
