Sponsored by: CARiD
SRS Warning 2003 D2
Old Nov 24, 2020 | 04:30 PM
PEZDisco2's Avatar
Default SRS Warning 2003 D2
SRS popped up yesterday. Any suggestions, recommendations?
Old Nov 24, 2020 | 06:20 PM
acg's Avatar
acg
See if you can find someone with a code reader such as a Nanocom or Hawkeye. It will give you a more specific error code readout. Two common SRS faults are: airbag (rotary coupler) or seat pre-tensioner. Good luck!
Old Nov 24, 2020 | 06:37 PM
PEZDisco2's Avatar
Default Thanks for the reply.
I’ll check in with my local import independent.
I hope it’s not the clockspring. If it’s anything like Mercedes, it will be worth more than the truck!
Old Nov 25, 2020 | 08:04 AM
JUKE179r's Avatar
If the fault is due to the driver's seat pre-tensioner, just push and wiggle the pre-tensioner wiring at the base of the seat.
Old Dec 4, 2020 | 04:56 PM
PEZDisco2's Avatar
Thanks
Faults indicated that both seat belt buckles are faulty. Codes were deleted but the passenger seat buckle flashed up a fault as soon as the technician restarted the beast.
ftby55
Apr 20, 2014 08:44 PM
wilson96rr
Dec 14, 2009 08:44 PM
NATEDOGG
Oct 14, 2009 03:27 PM
dezlpower
Sep 11, 2009 07:30 PM
aublec22
Sep 17, 2007 08:29 AM
