Steering -Steering Pump and Front End
Hey Everyone,
About 4 weeks ago I picked up a beautiful 2004 Disco. It needs some work, mainly in the gasket area with all the common leaks most have. I'll be getting to that a little later... on another date....
Right now I would like to take care of the front end. I do have the wonderful death wobble, its not so noticeable under 40Mph but its there... I might have gotten used to it by now but you defiantly feel the wheels moving around under you when going over bumps while steering wheel is not adjusting accordantly.
I brought my Disco in to a Land Rover shop that is not actually Land Rover. With how busy they are and all the positive feed back online I wanted to see what they had to say.
They gave me a good list of work again mainly gasket work... but looking at what they had to say about my steering...
They said the steering pump needs replacement and that its leaking heavily.
I looked at my PS fluid and it is on the lower end of the levels but checking on it since I got it, I have not seen it drop. I will say the fluid looks pretty dark and old.
Along with the power steering pump they also wanted to replace the suction hose.
I'm wondering why the suction hose, it looks fine to me? Is this a common hose with steering that needs to be replaced? I understand the power steering system to a point in the Disco and the hoses that connect it. So I'm just wondering why that hose and not the others?
I'm also wondering about the steering fluid... I know this can be its own post but just one question...
The Land Rover Power Steering Fluid... in the video on replacing the power steering pump on rover-parts they say how that fluid will make the pump last longer. I'm just wondering if thats marketing and just a sales pitch and if there is any proof to that?
The other thing the LR shop said all my Tie Rod ends are lose/worn.
I would like to just go ahead and replace the set up with a heaver system
These are the ones LR people put on for Tie Rod and Drag Link
Drag Link Complete (Same Fit As Genuine Part # QHG000050) For Land Rover Discovery II | Land Rover Steering Parts
Track Rod Complete (Part # TIQ000010) | Land Rover Steering Parts
I was intersted in the Terrafirma Track Rod & Drag Link Assembly Land Rover Discovery 2 Terrafirma Steering Rods - from what I read online it looks like a good set up.
So here is just a quick recap of the parts I'm getting, would love to get your thoughts but these seem straight forward.
Steering Damper
Old Man Emu Steering Damper (Same Fit As Genuine Part # OMESDO2) | Land Rover Steering Parts
Steering Pump
Land Rover Discovery II Steering Pump (Fits Part #QVB500080)
Steering Fluid ( need to research this)
ACE And Power Steering Fluid Range Rover Sport
Track Rod and Tie Rod
Thanks again everyone! Exited to be apart of this community
Urusla
Steering Damper
Steering Pump
Urusla
Update
Going to start on front end first before I tackle the steering pump.
I have been watching the levels on the steering pump and they have not dropped at all since I got the truck. So I figure I will keep that pump running till it starts to really crap out on me.
I was wondering if I should change the steering fluid as it is pretty dark looking... but then again should I mess with it if its still working?
I bought the Terrafirma Track Rod & Drag Link Assembly along with a EMU Steering Damper.
Will have the parts on Friday and will install that day or the next. Looking forward to seeing how much play this will take out from the steering and what if anything else will need to be replaced to get that steering dialed in.
check back for before and after pictures and results!
Thanks! Thats a good point! I will do a few test drives with the Damper off to see how see how she handles.
I'll post my results this weekend.
see for yourself -
justryan,
I will try this once again, as i know your trying to help.
but DII does not have serviceable wheel bearings, it is a fulling enclosed hub as stated.
You may want to watch your u tube video at the 3-minute mark where he explains that it is a full enclosed hub non-serviceable and if there is any issue it requires the complete hub to be replaced.
