Sponsored by: CARiD
Still no fuel on 97 Disco
Old Apr 29, 2007 | 02:44 PM
Doss's Avatar
Default Still no fuel on 97 Disco
I swear before I ordered a fuel pump I was getting 12V and 6V at the plug going into the pump.
I ordered a used pump, instatalled it with no change.
I was troubleshooting today. At the plug on the pump I am getting 6 volts on the green wire, but nothing on the other wire.
I worked backward to the Inertia switch and have no voltate there.
Next step is the relay.
Any suggestions there? Do most people hacksaw it open?
I have learned that there should be voltate going in at pin 7 and coming out of pin 4.
I will go back and check that.
One big question:
Should there be a constant 12V at the fuel pump? I think there should.
I know on most vehicles, once you go to ON, the pump only runs for a bit and then kicks off. Is it the pump shutting off or something further upstream?
Any help will be appreciated.
Old May 1, 2007 | 06:43 PM
ArizonaDiscovery's Avatar
Default RE: Still no fuel on 97 Disco
Is the pump actually running? How many miles on your vehicle? ---hate to ask this but the last time you changed your filter??
Old May 2, 2007 | 02:25 AM
okdiscoguy's Avatar
When you turn the key, the pump runs to build pressure and turns off. Check the valve on your rail to see if you have pressure. The filter is a cheap easy swap if you haven't done it, wouldn't hurt. If you need a manual, they are free at rover-renovations.com. Search the RAVE CD. Do you know where the relay is? I would check that before the inertia switch. It is easier to find..
hankmcrae
Apr 4, 2013 09:07 PM
cta
Aug 17, 2012 08:10 AM
JumPeR04
Apr 7, 2011 09:52 PM
derek010
Dec 4, 2010 12:13 PM
RobSchmidt
Oct 29, 2009 02:23 PM
