Sponsored by: CARiD
Strange noise
Old Jun 14, 2021 | 12:03 PM
longshot's Avatar
Default Strange noise
I have a 00 disco with 2” lift and slightly large tires, not a daily driver. Just turned 89k miles. Has disco I dif-lock linkage. Starting last fall, in hunting camp, it was making a clicking noise on acceleration or up any kind of hill. The noise changed with vehicle speed. After about 30 mph it went away. The noise sounded like the passenger CV. I replaced the CV and hub. No change. Replaced pinion and carrier bearings. Still no change. Now the noise is getting very loud. Started off as a click now it sounds more like a knock and I can feel it in the t-case shift handle. Doesn’t matter if the t-case is locked, the noise doesn’t change. Recently it is bad enough it’s more like a banging. Ordered new CV and hub for drivers side. They sent me the wrong axle shaft but when I pulled the old axle the CV feels fine. The hub feels a little rough but not bad enough to account for the noise. No noticeable vibrations. Doesn’t matter if the t-case is in high or low range sound is at vehicle speed. Any suggestions? Also any suggestions on how to remove an axle nut. Thanks.
Old Jun 14, 2021 | 02:39 PM
Harvlr's Avatar
Hi longshot. I think you should post this in the Disco 2 part of the forum as there will be more traffic there
Old Jun 14, 2021 | 03:42 PM
mollusc's Avatar
Agreed, post it in the D2 forum.
But it sounds like your front driveshaft may be living on borrowed time. Fix it immediately, before it grenades and takes out your transmission.
Old Jun 15, 2021 | 10:32 AM
longshot's Avatar
Thanks, will do.
Old Jun 15, 2021 | 10:33 AM
longshot's Avatar
I forgot to mention the front DL was rebuilt shortly after the noise started.
Old Apr 7, 2022 | 08:26 AM
AllysonCSanchez's Avatar
4th Gear
Thanks for the suggestions. I will surely keep them in my mind. By the way, do you want to read essay examples online for free? If yes, then you can easily find them on this https://www.topessaywriting.org/samples/illness website. I am a school student and I also use that website to read free essay examples.
Old May 21, 2022 | 06:01 AM
severiano's Avatar
Speed Test
TOM R
Sep 15, 2020 03:50 PM
nychaze
Aug 22, 2013 02:20 PM
Disco28
Feb 27, 2013 10:49 PM
marshman442
Sep 23, 2011 09:37 PM
robbie1400
Mar 26, 2008 03:56 AM
