Sponsored by: CARiD
Telescopic Steering Squeaks
Old Mar 21, 2007 | 07:53 PM
sysroute's Avatar
Default Telescopic Steering Squeaks
When I turn the engine off and remove the key the steering returns to its original position. While it is doing so it squeaks like it needs to be lubricated. Does anyone know where/how I might go about fixing this annoying problem?
Old Mar 21, 2007 | 09:53 PM
Bill E's Avatar
Default RE: Telescopic Steering Squeaks
You may need to get some help from someone to check if the sound is coming from under the bonnet at the base of the steering column, there is a short shaft with a couple of universal joints it maybe from there, but it is hard to check out if you are in the drivers seat.
If so I fixed mine by spraying the rubber parts with a Lanoline lubricant which shouldn't damage the rubber.
Hope this helps
psykokid
Apr 12, 2012 01:18 PM
ESPN
Feb 16, 2012 07:40 PM
funkymunk
Nov 29, 2008 06:56 PM
tads
Aug 27, 2008 04:15 PM
Brad S1
Nov 2, 2006 08:10 PM
