Sponsored by: CARiD
Throttle body defroster?
Old Oct 31, 2007 | 11:09 PM
Deb99DiscoII's Avatar
6th Gear
Default Throttle body defroster?
Antifreeze was spraying outaround the 2 hoses @ the throttle body. A local mechanic gave me a quick fix bycapping off the hoses & saidit looked like the "throttle heater" was cause .. alsosaid I shouldn't have a problem until it gets cold. Only part I could find online is a throttle body defroster ( ~$20).Do I need a gasket(s) with this replacement? I couldn't find apicturethat would helpIDdetails. This doesn't look too difficult but I don't want to tear it off to find out I can't put back together inthedriveway.
Thanks, Deb99DiscoII
p.s.- I have a pic that is too large to embed here/
Old Nov 1, 2007 | 12:20 AM
ajh's Avatar
ajh
Default RE: Throttle body defroster?
It's probably only the gasket, they're known to go.
Old Nov 1, 2007 | 01:36 PM
There is a new Rover updated kit to repair that very common problem, or you can do as I did and use a small piece of coper pipe and join the two hoses togeteher, works great here in Colorado.
Old Nov 1, 2007 | 07:46 PM
6th Gear
Thanks for the help!! Very glad to find this forum! I'm going to give it a closer inspectiontomorrow night, if I get stumped, I'll add note here...Stay turned for my next issue I used 1/2 can of degreaser onengineet al...looking for my antifreeze leak(s) next... "I'll be back."
SenatorPerry
Jul 15, 2013 10:28 AM
hawkridesdirt
Oct 22, 2011 10:51 PM
G4AKumar
Feb 26, 2010 04:33 PM
leadfoot
Feb 24, 2010 07:48 PM
99XJ
Jul 19, 2007 09:22 AM
