Sponsored by: CARiD
throttle potentiometer
Old Jan 17, 2017 | 09:05 PM
burl's Avatar
8th Gear
Default throttle potentiometer
disco 97 diesel jap import --problem -- car staggering as though no fuel in forward gears when driving but consistently not consistent ..sometimes it runs smoothly for a while and then can almost completely choke my throttle to be useless -throttle potentiometer ?? the weird thing is in REVERSE there isnt a problem ?????????????? ideas guys ???
Old Jan 18, 2017 | 02:42 AM
burl's Avatar
8th Gear
anybody have some idea about this sort of fault and why reverse would be fine but all forward gears coughing and spluttering horribly and then running fine -chocking -on and on
Old Jan 18, 2017 | 08:22 AM
WaltNYC's Avatar
Does is idle fine, and does the engine rev smoothly while in park? If so my first guess is VSS.... but that is just a guess.
Old Jan 18, 2017 | 01:21 PM
burl's Avatar
8th Gear
hi and thanks for reply. The idle is fine and when i rev it mostly its fine . As soon as i go into drive it starts chocking .. what is vss?
Old Jan 18, 2017 | 01:51 PM
burl's Avatar
8th Gear
whats got me beat also is why the reverse has zero problem with choking where as the forward auto gears are having a real hard time sputtering and choking and almost become undrivable -??
Old Jan 18, 2017 | 01:58 PM
mollusc's Avatar
VSS = Vehicle Speed Sensor. Which would make sense with the difference between forward and backwards movement.
Old Jan 18, 2017 | 02:02 PM
burl's Avatar
8th Gear
what are the faults that happen when this sensor decides to spit the dummy ?and good observation if it reacts differently to reverse and forward ..any other possibilities ?
Old Jan 18, 2017 | 02:48 PM
burl's Avatar
8th Gear
someone has also suggested the injector pump when under load which would explain the reversing situation being ok given there is less load in reverse or a vacuum problem
Old Jan 19, 2017 | 08:05 AM
WaltNYC's Avatar
Truth be told there is not a ton of diesel expertise (that I have seen) around here. Your question might draw better responses over at defendersource.
Old Jan 19, 2017 | 01:58 PM
burl's Avatar
8th Gear
appreciated
schwaggy
Jan 29, 2019 10:42 PM
SenatorPerry
Jul 15, 2013 10:28 AM
azeri
Sep 27, 2006 10:22 PM
Doss
Mar 26, 2006 06:00 PM
Jimbo
Aug 9, 2005 11:09 AM
