Transmission fluid
Transmission fluid
Good evening forum. I had a little issue today. So I noticed that my 03 d2 was not shifting as smooth as it was. I figured it might be low on fluid. I followed another members tutorial here on adding tranny fluid, started the truck, let it run to temp, went under truck, removed fill plug and fluid started pouring out. Being the butter fingers I am, I dropped the plug, quickly reached for it and put it back on. I did however lose about a quart or so of oil. Did I do something wrong? Was I supposed to have the truck in gear or something? How can I replace the quart or so of fluid if it keeps pouring out when I remove the plug.
Thank you forum for any help. I Am new to the land rover world ( obviously lol ), but am looking to learn alot from the other members.
Dave
Dave
You may as well drain the entire contents of the pan, and replace with fresh. Three quarts. Replace plug. Let truck warm up, shift through each gear. Recheck level at tranny disptick under hood (not the oil one, the other one). Add if needed. After driving, check again. And again next morning after sitting overnight. The tranny holds more fluid, but half of it is inside the torque converter and difficult to remove. Some members do one fluid drain and fill, then after running truck and letting it cool down they do a second, figuring that 75% of the fluid will be new.
For those that want to remove modest quantities of fluid without the drain plug, in the Home Depot lawn mower aisle they have a manual oil vac pump, it can suck tranny fluid, PS fluid, various oils, out through the dip stick hole or inspection hole with a small plastic tube.
LRScott
03-04-2009 08:39 AM
