Sponsored by: CARiD
Trouble with my Disco II, need help fast
Old Sep 12, 2009 | 11:05 AM
tbarker13's Avatar
7th Gear
Default Trouble with my Disco II, need help fast
I'm out of town on vacation - a long way from home - in the Smoky Mountains. Staying in Gatlinburg area.
Our 2000 Disco II started developing a problem yesterday. It started stuttering while driving. Acts like something is interrupting the fuel supply. At first, it was a pretty rare occurrence - every 15 minutes or so. But this morning it got much worse. The stuttering is particularly bad just as you press in the gas pedal. The Disco also seems to be losing some power as well. The "service engine soon" light also is blinking.
I'm supposed to head home tomorrow morning - and it's a long 500 miles to St. Louis.
I'm guessing this is a problem that's not going to wait until I get home to fix it. Any thoughts would be much appreciated. Looking around right now to see if I can find any Land Rover repair folks in this area.
Old Sep 12, 2009 | 11:07 AM
Do you have a check engine light on, if so, go get the codes read? Have you checked your air filter?
How many miles on the truck, what gas are you using and when was it last tuned including wires?
hilltoppersx's Avatar
see if you can find an auto zone or another parts store that will read the codes for free and get back to us with the codes.
Old Sep 12, 2009 | 02:46 PM
tbarker13's Avatar
7th Gear
Ok,
I could only find one mechanic open at this point on Saturday - and he was closing up shortly after I called. So I ran the truck over.
It has 82,000 miles. Only use premium gas.
The check engine light was not on. But the Service Engine Soon light was on and blinking.
It has been a while since the last tuneup (not sure about the mileage and the records are at home). The mechanic said the wires looked pretty bad. Suggested a tuneup might do the trick.
He read the codes, which said there were misfires in cylinders 2 and 3.
Also gave the dealer code 1300.
Old Sep 12, 2009 | 03:50 PM
Your service engine light is your check engine light.
Time to order a set of 8 mm Magnacor wires and some good Plus 4 plugs.
Do not continue you drive it much with that light flashing, you will burn out your cats.
Old Sep 12, 2009 | 03:56 PM
tbarker13's Avatar
7th Gear
Thanks,
The mechanic is replacing the wires and plugs Monday morning. We'll have to stick around a day longer than planned - but sounds like that's a much better option than trying to to drive it home as is.
russdouble
Dec 9, 2010 10:59 AM
ciablackops
Nov 14, 2010 02:59 AM
tunernewb92
Oct 20, 2009 07:15 PM
adamsdisco2
Jun 3, 2009 09:38 PM
sv650k4
May 27, 2007 07:58 PM
