Sponsored by: CARiD
trying to replace idler pulleys
Old Apr 4, 2013 | 09:42 PM
a-rod's Avatar
Default trying to replace idler pulleys
I am trying to replace both idler pullys on my 2000 land rover disco II,
but its not going well for me.I cannot get the bolts to budge, ive used 13mm socket with a breaker bar,ive used 13 mm box and open end wrench
nada.nothing,no movement,
what am i doing wrong!
any advice your willing to give would be appreciated
Old Apr 9, 2013 | 12:14 PM
eitydeuce's Avatar
I recently did mine too and had similar issues. All I can say is try to soak them with a penetrant and let it soak overnight. If you can't get it loose with a wrench don't try to pry it off otherwise you will definitely break something. The new WD 40 rust release seams to work good. I used it on all my exhaust bolts and didn't break a single one. Be sure to soak the heck out of it and let it sit for a while.
Old Apr 9, 2013 | 02:40 PM
04duxlr's Avatar
PB Blaster. Soak and wait.
Old Apr 9, 2013 | 03:52 PM
You should replace all 3 at the same time which includes the pulley on the belt tensioner.
mountainrovernc
Freelander
Apr 3, 2019 01:13 AM
Discovery steve
Dec 18, 2014 12:04 AM
redrover75
Oct 30, 2014 03:33 PM
malibutj
May 25, 2011 01:46 PM
Jawbox
Oct 26, 2008 10:05 AM
