Turn signal issue 2000 disco 2
i had a similar problem on my early 2000, there are two flasher relays in the compartment under the steering wheel, try swapping them.
That was my problem, one of the flasher relays were bad.
Now it depends what date your truck was built how hard it will be to get the flasher, they had a running change, early models used a black flasher and later a yellow they will not interchange.
