Sponsored by: CARiD
Turn signal issue 2000 disco 2
Old Jul 25, 2015 | 01:23 PM
Sandor's Avatar
Default Turn signal issue 2000 disco 2
When I turn on my left turn signal it blinks once, and that's it. My right one works fine. What can cause this? Thanks
Old Jul 25, 2015 | 05:29 PM
Have you checked both front and rear bulbs for a failing light bulb?
Old Jul 27, 2015 | 07:16 AM
drowssap's Avatar
i had a similar problem on my early 2000, there are two flasher relays in the compartment under the steering wheel, try swapping them.
That was my problem, one of the flasher relays were bad.
Now it depends what date your truck was built how hard it will be to get the flasher, they had a running change, early models used a black flasher and later a yellow they will not interchange.
Old Jul 27, 2015 | 06:34 PM
Sandor's Avatar
Thanks it was the flasher relay. I swapped them and it did the trick. Its the yellow one I just have to find one.
Old Jul 28, 2015 | 05:09 AM
drowssap's Avatar
yellow not that bad, the black are much harder to find
Thomas Lane
Aug 14, 2015 10:25 PM
xrundelek
Jan 11, 2011 08:32 PM
85Red110
Defender
Nov 19, 2010 03:51 PM
AnnelieseMae
Feb 24, 2009 12:14 PM
D2000
Jun 8, 2007 11:12 AM
