turn signal issue
The info on it is in the owners manual.
If the trailer is connected it flashes in conjunction with your indicators.
If a trailer light is burned out, it will flash once then remain off.
If no trailer is fitted then it will flash once then remain off until the switch is operated again.
If you have high wattage bulbs in your indicators it could cause it to flash all the time since it's based on the load on the system.
