Sponsored by: CARiD
turn signal issue
Old Jan 10, 2011 | 12:38 PM
xrundelek's Avatar
Default turn signal issue
hello everybody! i recently bought a 1998 discovery and i notice that every time i switch my turn signal on, it shows blinking trailer picture next to blinking arrows. does anyone know if that's how it supposed to be or what could be wrong. thanks!
Old Jan 10, 2011 | 01:08 PM
Chris-bob's Avatar
Mine does that too. I assume it is supposed to do that since all the lighting is working correctly.
Old Jan 10, 2011 | 02:12 PM
lordmorpheus's Avatar
You don't have a trailer connected do you? It IS supposed to do that while a trailer is connected, but not when there isn't. I believe the extra load on the wiring is what activates it. You might check your trailer plug to see it it is shorted or corroded.
Old Jan 10, 2011 | 02:40 PM
antichrist's Avatar
The info on it is in the owners manual.
If the trailer is connected it flashes in conjunction with your indicators.
If a trailer light is burned out, it will flash once then remain off.
If no trailer is fitted then it will flash once then remain off until the switch is operated again.
If you have high wattage bulbs in your indicators it could cause it to flash all the time since it's based on the load on the system.
Old Jan 11, 2011 | 08:32 PM
xrundelek's Avatar
Thanks for the info! And no, I don't have trailer connected
abran
Oct 10, 2013 09:00 PM
Andy2Rover
Jan 5, 2012 06:58 PM
85Red110
Defender
Nov 19, 2010 03:51 PM
AnnelieseMae
Feb 24, 2009 12:14 PM
D2000
Jun 8, 2007 11:12 AM
