Sponsored by: CARiD
Universal Joint & Yoke
Old Dec 22, 2008 | 02:45 PM
98P38's Avatar
4th Gear
Default Universal Joint & Yoke
Lost the U-Joint and Yoke on the front diff of my 98 range rover. Anyone know where I can find the Yoke or do I have to buy the whole drive shaft assembly like the dealership says.
Old Dec 22, 2008 | 05:05 PM
Default RE: Universal Joint & Yoke
So are you saying you damaged the flange that the drive shaft hooks to on the t/case or part of the rive shaft itself?
If it is the drive shaft, yeh, you don't want to spend the money to rebuild it if it s damaged.
Two options, Tom Wood's Custom Drive shaft for a new replacement or Roverlandparts.com for a guaranteed used shaft.
Old Dec 23, 2008 | 12:17 PM
98P38's Avatar
4th Gear
Yea exactly the flange on the front diff is damaged as well as the u joint itself.....I was driving very slow as I felt it start to vibrate so no other damage is apparent. Would like to use the same drive shaft and same u joint and yoke up at the transfer case and just replace the differential yoke and ujoint......
Old Dec 23, 2008 | 12:52 PM
If the drive shaft is OK and all you damaged was the u-joint then order a Percision 344 u-joint, as for the flange, try Landroverparts.com
Mike
Old Dec 24, 2008 | 04:06 AM
rinmud's Avatar
lucky you didnt wack a hole in the hp24 r5 ( auto trans) buy the complete shaft man, a trans is a lot more scott
Old Dec 24, 2008 | 05:45 AM
rinmud's Avatar
sorry the coffee got to me hp-24 r-4 sorry scott
believe it or not I put a disco II trans in my friends BMW '96 740 all i had to do is change out the tail shaft housing (transfer case) and put his old housing on scott
Old Dec 27, 2008 | 02:26 PM
98P38's Avatar
4th Gear
Yea I ended up going by West Coast Rovers here in socal and he was piecing out another P38 so he sold me the whole driveshaft assembly for 200 bucks. Figured that was the right way to do it. He was also suprised the drive shaft didnt do more damage, said he just reapired one where the u-joint failed and exactly like you said went through the tranny and everything else. I felt the vibration a little early and knew it was drive shaft and told my wife to slow down and pull over and we were doing about 15 mph when it snapped so it didnt get thrown around to much.......Just finished fitting the new shaft this morning so ready to go out for new years to the desert and run it....
Old Dec 28, 2008 | 01:30 AM
rinmud's Avatar
I go to desert hot springs about once a month with my friend jamie (owner of AVC aviation) usually in Air Ambulances he services there for customers. "8 seats all smoking and one right seat" the real animals are out there. Seen trucks do amazing s..t. He has three old sunbathed jeeps out there that are not much to look at but when it comes to dragging out a victom??? a rover does the job. I like the desert but its 30 miles to the beer store and you dont even need license plate no one gives a s..t. The indian reservations are wonderful (best people and hosts I ever met). scott
thelod
Jan 5, 2013 01:44 AM
LeakyDisco
Sep 29, 2010 10:56 AM
JBEGIN
Nov 4, 2008 11:58 AM
Mountainman
Defender
Sep 4, 2007 12:15 PM
mowthat
Mar 18, 2007 05:44 AM
