Sponsored by: CARiD
Used engine vs. rebuilt
Old May 26, 2015 | 03:53 PM
polarbare's Avatar
Default Used engine vs. rebuilt
Can anyone who is experienced with LandRover Discos 2004 help me decide whether I should have my engine replaced with a used one, or just have the engine rebuilt..I am aware of the cost difference..but I want the car to be running as best as it can be when I am finished..also, who do you recommend in the entire US? anyone in California?
thanks
Old May 26, 2015 | 05:57 PM
abran's Avatar
I have went both routes.
The rebuild I did ended up with a tick in the motor which I still have not resolved, but I am pretty sure why I have it. I started with a Block that had problems. I should have used a top hat block.
My wife has a used motor and we have no problems.
If you go used, try and hear it run before they pull the motor. Even if someone gives you a warranty, they won't cover the install and un install of the motor. I have a mechanic that charges $800 for an install, so that could end up being $1600 you are out of pocket on just so you can test another guys motor!
Old May 27, 2015 | 06:08 AM
drowssap's Avatar
If you plan on keeping it your best bet is rebuilt, the odds are any used motor is going to have a problem or be looking towards one in the future.
if you can afford it this is you best bang for the buck right now:
turner-engineeringco.uk
DISCO JAK
Aug 20, 2013 06:48 AM
kman35ca
Dec 12, 2011 09:31 PM
mrcrptguy
Apr 19, 2009 09:49 AM
aublec22
Feb 6, 2008 09:18 PM
