Sponsored by: CARiD
water leak coming from ATC blower ?
Old Oct 11, 2013 | 08:42 PM
aftermath431's Avatar
Default water leak coming from ATC blower ?
2000 Disco II. I have a leak that's dripping onto the floor mat with the a/c off when I use a squirt bottle to check for leaks. its not coming from the windshield our sunroof drain hose it looks like its coming from the ATC blower screws that is under the glove box. when I spray water below.. the lower windshield gasket it comes dripping out the ATC blower and onto the floor mat. anyone have a idea how this can be?
Old Oct 13, 2013 | 05:11 PM
OffroadFrance's Avatar
It sounds like the AC drains are blocked and the catch tray is overflowing into the front cab area. Check underneath the truck each side of the transmission tunnel alongside the gearbox, there are two small rubber drain pipes 3/8" diameter by 3" long, one each side, there is a flat gland on the end of each that becomes 'gummed up' with grime. Squeeze each of these glands and the water will pour out (don't be underneath them at the time and keep your mouth closed - I can vouch for that) and then spray the drains and glands with silicon spray or WD40 which should fix the problem.
Old Oct 14, 2013 | 09:24 PM
Thanks. I did a heator core flush with a water hose and didn't get any water inside. I also squeezed the the rubber drains and tried running a wire up in the one I thought might be clogged. Tomorrow I will use a hose and spray below the windshield and see if water still comes in. So water can get into the cabin (kick panel area) from rain in the drains are clogged? Im asking because I don't get water in the cabin with the ac/heater on only when I was my Disco with a hose. But i'm glad the windshield and sunroofs are no longer leaking after repairing them.
Old Oct 15, 2013 | 06:54 AM
acamato's Avatar
Where are you spraying the water below the windshield? The fresh air intake to the HVAC is under the cowl. If water gets to the intake, it will get to the blower. If the cowl/windshield seal isn't working, you will get water by in the blower.
https://landroverforums.com/forum/di...g-there-48292/
'BamaBoy
Mar 22, 2010 11:19 PM
ggothlin
Jan 16, 2009 08:06 PM
bigbadbannana
Dec 15, 2007 06:26 AM
GAZ LUKAS
Oct 24, 2006 05:53 PM
Brad S1
Jul 5, 2006 05:54 PM
