Sponsored by: CARiD
WATER PUMP REMOVAL!!!!!!! PLEASE HELP!
Old May 14, 2005 | 02:58 AM
mke137's Avatar
Default WATER PUMP REMOVAL!!!!!!! PLEASE HELP!
FOR A 98 LANDROVER DISCOVERY THE NUT TO REMOVE THE FAN FROM INFRONT OF THE PULLEY YOU TURN IT COUNTERCLOCK WISE (this is FACING THE ENGINE!!!!!) ive been working on this for a whole freakin day! so just tell me if im turning it the wrong way PLEASE!!!!!!!!!!!!
Old May 15, 2005 | 03:26 AM
Bait's Avatar
Default RE: WATER PUMP REMOVAL!!!!!!! PLEASE HELP!
98 NAS Disco. Removal of the fan, facing the front of the engine is counterclockwise.
Old May 15, 2005 | 04:19 AM
mke137's Avatar
do you really need to have an "impact" (like an impact wrench) to break this nut free? and if you do...then how in the world would you even be able to utilize an impact gun?!?! and when and if i am able to get this fan nut off...how tight do i want to make it on installation?!?!
Old May 15, 2005 | 02:54 PM
Lighting90's Avatar
You need a special fan nut tool for it to work well I found. A standard spanner is at too much of an angle and you can not get enough force on it to make the nut turn. Using a the special bent spanner, it was so easy..
Danobp
Jun 3, 2014 04:15 AM
Sgt.Stone
Feb 2, 2013 02:25 PM
Savannah Buzz
Jul 21, 2011 08:02 PM
rlrigsby
Mar 22, 2010 03:20 PM
roverohio
Feb 25, 2010 12:00 AM
