Sponsored by: CARiD
What's up with this throttle cable?
Old Oct 27, 2023 | 04:15 PM
binvanna's Avatar
Default What's up with this throttle cable?
I opened the black bag from Rover's North (Proline) that I bought a couple years ago. I hope I didn't get a defective part. Why isn't the spring housing closed like on the cable that I'm replacing?
Old Oct 28, 2023 | 02:15 PM
Harvlr's Avatar
What vehicle?
Old Oct 30, 2023 | 01:59 AM
binvanna's Avatar
It's a D1. The new cable was a 'Pro-Line' from RN. I installed it to see if it would work that way, but it was undriveable. I put my old cable back. I'll see if they will replace it. I'm not sure I understand the purpose of the captured spring. It doesn't provide a return or anything. The cable moves freely in both directions. There is a light return spring on the pedal and the main return spring is on the throttle body. I'm guessing the spring is just supposed to push on the cable housing so that it doesn't need a positive attachment to the bulkhead.
Old Oct 30, 2023 | 05:24 PM
Harvlr's Avatar
Try posting in the D1 section of this forum. You’ll get a lot more views.
Old Nov 16, 2023 | 11:54 AM
danyjames_9's Avatar
Banned
did you solve it ?
Old Nov 17, 2023 | 03:31 PM
binvanna's Avatar
I had to re-install the original cable. The reason I wanted to replace it is because the plastic snap fitting that holds it in the bracket at the throttle body has one of the four tabs broken. It's still functional. I purchased this replacement cable from RN three years ago, so they refused warranty. I believe the supplier is Britpart -- which has obviously supplied the piece with horrible quality control, putting their customers at risk. I've had throttle cables fail while driving, and I can tell you, it's a very, very serious danger. Because I don't trust a replacement part, I will epoxy the spring housing myself, and then secure it with safety wire.
WildPackofFamilyDogs
Jun 13, 2022 05:23 PM
philwarner
Mar 30, 2017 11:16 AM
TRIARII
Mar 28, 2017 08:28 PM
toofaroffroad
Dec 30, 2012 11:51 AM
LRD2&ME
Apr 23, 2011 02:19 PM
