Sponsored by: CARiD
wheel bearings loose
Old Dec 8, 2012 | 09:31 PM
binvanna's Avatar
Default wheel bearings loose
I was wobbling today so I set the front axle on stands and checked the wheel bearings. They were loose enough to shake the wheels. End play was set by using the 61Nm/90 deg. back off/4Nm method and then locked in with a tab washer and second nut at 61Nm. I repeated the procedure today, 'bout 6000 miles since new, and the nuts ended up about 45 degrees clockwise from last time. Seems like they got loose pretty early. I wonder how long before I have to replace them.
Rover Curious
Dec 23, 2011 05:26 PM
robot808
Nov 18, 2009 11:10 PM
bklahl
Oct 12, 2006 04:38 PM
bklahl
Oct 10, 2006 03:11 PM
sanmigmike
Aug 24, 2006 03:37 PM
