Sponsored by: CARiD
Whistle while you drive?
Old Apr 9, 2009 | 10:07 PM
palabratic's Avatar
7th Gear
Default Whistle while you drive?
I have a whistling that is directly related to rpm under load but only occurs above 10 mph... It sounds like a belt squeal, just a little higher and at lower rpm it puffs.... like airflow.. I am looking for a diagram for the vacuum lines if anyone knows where to find one???
99 discovery II
Old Apr 12, 2009 | 12:00 AM
oldrovertech's Avatar
check your idler pulley is it made out of plastic or metal? and if it is metal does your cruise control work?
Old Apr 14, 2009 | 12:39 AM
palabratic's Avatar
7th Gear
metal, and yes, the cruise control is fine
Old Apr 15, 2009 | 08:13 PM
sometimes an excessive amount of dust can build up on your pulleys and can cause a whistle type noise. if you live in a dusty place try blowing them out with an air gun. and i will get you a vacuum diagram, and the sai injection routing. check all the above and let me know if it gets any better.
Old Apr 16, 2009 | 04:14 PM
palabratic's Avatar
7th Gear
well. dusty isn't really applicable. We are in fairbanks alaska and the problem started around -20 weather, but temp doesn't seem to matter.. it's breakup now and we have driven through deep water and soaked the entire engine compartment, to no avail.
CrimsonRavyn
Feb 26, 2012 09:40 PM
calebbo
Oct 12, 2011 09:54 PM
Randy P
Sep 27, 2007 08:27 AM
ghinesley
Aug 6, 2007 01:48 PM
LordOphidian
Jan 31, 2007 01:42 PM
