Sponsored by: CARiD
wierd noise
Old Feb 18, 2008 | 06:17 PM
jh063078's Avatar
6th Gear
Default wierd noise
my 99 disco s2 makes a rather strange, quiet noise while running. i only hear it when i pull up to stop and it sounds as if there is some sort of electrial motor that comes on for a quick 3 seconds or so, then it is quiet again. the noise is not very noticeable, but i am always listening for anything unusual. any info would help... oh and btw, it sounds like it is behind my glove box, or by it. if i open my glove box i can hear it better.
Old Feb 18, 2008 | 09:05 PM
WolfPack's Avatar
Default RE: wierd noise
This is just a guess, seeing as how I've got a Range, not a disco, but it could be the load leveler if Discos are so equipped. It won't kick in while moving, but at the stop it might attempt to level itself. Could be a height sensor going bad causing it to randomly start to 'level'.
Old Feb 18, 2008 | 11:03 PM
jh063078's Avatar
6th Gear
yea, that sounds like it could be it. do you know where those hieght sensors are located and where the load leveler is located? is it something i need to be worried about? thanks for the response! much appreciated...
Old Feb 19, 2008 | 10:20 AM
That is most likely your secondary air pump if you have secondary air, as an emission device.
Kiwijeff
Aug 18, 2015 08:22 PM
kavik
Dec 26, 2008 10:48 AM
msk2503
Nov 19, 2008 07:38 AM
dallasrover
Apr 15, 2008 05:40 AM
