Will removing Becm from truck lose any info??
The connector on the rear side facing the passenger side rear floorboard has been kicked probably a 1,000,000 times and is causing the ac control board to intermittently lose power. Gonna remove and take cover off and Hopefully be able to resoldier ... (Hopefully)))
i believe the soldier joints on the rear connector facing the passenger side rear floor board has some bad connections on the board. when i wiggle the connector the ac control board intermittently loses power
Richard1
Nov 30, 2005 04:40 PM
