Sponsored by: CARiD
Window Troubles
Old Aug 29, 2013 | 07:40 AM
TattooedLRD's Avatar
4th Gear
Thumbs up Window Troubles
I had 3 out of 4 windows that weren't working. I recently removed the ECU module and re-soldered the bad connections which got the 2 back windows working! The front passenger window still does not go up or down. There is power to the motor and you can hear it working when you press up or down but no movement. Could the motor still be bad even with power to it? Any suggestions are appreciated!
Thanx!, Mark
Old Aug 29, 2013 | 08:56 AM
Yep, can have stripped internal parts, or regulator parts. Door panel comes off gently.
Old Aug 29, 2013 | 11:48 AM
4th Gear
Cool.......Thanks!
Amazze
Apr 25, 2014 04:39 PM
Sean 1313
Jan 13, 2006 06:25 AM
nashvillerover
Dec 2, 2005 09:39 PM
oberdahill
Sep 10, 2005 11:17 PM
Dave_Liverpool
Jun 22, 2005 11:29 AM
