Sponsored by: CARiD
window won't roll up
Old Apr 8, 2008 | 07:46 PM
01DiscoII's Avatar
4th Gear
Default window won't roll up
My window is stuck down wondering if anyone has any sugggestions, there is noise when i press the button " i'm assuming the motor still works" but no movment, i've taken off door panel to see any obvious signs but none i can see, what should i check before purchasing a regulator?
Old Apr 9, 2008 | 07:25 AM
Default RE: window won't roll up
You have a broken window regulator.
How mechanical are you?
Here is a site to buy good guaranteed used ones from, http://www.roverlandparts.com/index....S&Category=411
Old Apr 9, 2008 | 01:02 PM
DiscoOn22s's Avatar
or you can take it to a weld shop and have them reweld it for you with a much stronger weld than those 3 little spot welds. however i would check the rolling plastic wheels to see if they are rolling freely or if they are broken. whatever you do just remember to clean your window when your done before you roll it down again. the grease or dirt whatever on the window will make it get stuck on the rubber trim and then that will damage your regulator. get some powder like chalk or something and sprinkle some on the inside of that rubber trim to give your window a nice slippery dry surface to roll down on.
evansjoem
Sep 30, 2014 07:14 PM
SC Rovergirl
May 15, 2010 07:06 AM
01DiscoII
Apr 9, 2008 03:57 PM
dailyuser
Aug 12, 2005 02:50 PM
95discotn
Oct 13, 2004 09:28 PM
