replacement muffler
Hello!
Well my DII just gets louder and louder and my mechanic saw the seem starting to come apart on my muffler back in January.
Now I've got to pick one.
I have to say the quieter option is more appealing to me I think...
I've had a number of people tell me I should probably go the Stainless Steel option or else I'll be replacing it all the time...
My mechanic says he can get one (I'm assuming not stainless) from NAPA for $206.
I've been looking at a few of the online options:
Rovers North - they call it a silencer? should I do other stuff at the same time?? - Discovery II Exhaust Pipe, Hanger, Muffler - Rovers North - Classic Land Rover Parts - $170?
Since I'm in Canada (shipping and duty are brutal) - Canada Parts Online - - has three options - Bosal and Starla??? $100-$135
And the offerings from AB:
Exhaust system kit - Land Rover Discovery II Exhaust System - $270
Genuine exhaust system kit - Land Rover Discovery II Exhaust System, 1999 - 2003 - $490
Muffler - Muffler Center D2 99-03 (WCE104642 Same Fit As Part # WCE104642 ) - Land Rover pipes from Atlantic British - $130
Genuine muffler - Muffler Center D2 99-03 (Genuine Part # WCE104642 ) - Land Rover pipes from Atlantic British - $200
Tail pipe with resonator - Tailpipe With Resonator (WDE100650 Same Fit As Part # 284-067 ) - Land Rover pipes from Atlantic British - $130 - should I replace this at the same time??
AND the Stainless Steel option - Magnaflow Performance cat-back kit - Land Rover Discovery II Exhaust System - Magnaflow Cat-Back - Single-Exit / Single-Tip - $590
I haven't priced with the dealership yet...
What do you guys recommend? Other sources?
Thanks!!!
TDC
Thanks!!!
TDC
i would only go stainless if i were going to replace everything, otherwise hit your local exhaust joint and have it replaced.
no need for a dealer, no need for costly factory parts
it cost me like $180 from the muffler back at a local muffler store
I would go with the muffler on back. I had to piece my muffler to fit the factory tail pipe and it was not much fun. Also found using a sawzall works much better than a cutting torch. no hot parts and cleaner cuts. I went with the Borla because of the lower price. sound is just fine and not too noisy.
