2008 LR2 coolant leak
Old Feb 2, 2020 | 06:19 AM
INTER911's Avatar
5th Gear
Default 2008 LR2 coolant leak
Next on the long list of problems with this vehicle is a coolant leak that left it disable yesterday. The leak appears to be coming from a small S shaped hose on the passenger's side. At one end it slips over a fitting and is held with a hose clamp. On the other end is a fitting that appears to be pushed into the engine block and held in place with a bolt. It looks like its leaking from the fitting or at least in that area. Its a bugger to get at. Moved the power steering reservoir out of the way and was able to get the clamp undone but the fitting is presenting a problem, can seem to get a socket on it. Anyone have any experience with this or even know what this hose is called or part number? Thanks.
Old Feb 2, 2020 | 06:30 AM
INTER911's Avatar
5th Gear
Found a picture of the hose in question. I can't determine what size socket is needed to remove the bolt holding the fitting in. Anyone know?
Old Feb 2, 2020 | 06:32 AM
INTER911's Avatar
5th Gear
Picture of hose. Anyone know size of socket to get the bolt off the fitting? I can't seem to determine it. Thanks.
Old Feb 2, 2020 | 09:05 AM
flybd5's Avatar
Based on your description I can't figure out what you are talking about. Picture(s) would help. I *think* you are talking about the coolant intake hose but I am not sure.
Old Feb 2, 2020 | 11:39 AM
INTER911's Avatar
5th Gear
This little hose. The upper connection slides into the engine and is secured with a bolt, I can't get a socket on it. While I'm at it, taking off the intake plenum to get better access a few electrical connectors have to be disconnected. Does anyone know how to disconnect? I always seem to do something wrong and end up breaking them. I there a lever, pin, ? Hard to see. Thanks.
Old Feb 4, 2020 | 06:15 PM
p_gill's Avatar
I replaced that hose on my LR2 and S80 (same engine for both)
And I am nearly certain that I took those pictures.
I am really glad that the pictures are helpful
To answer your question you need the following
Hose
O ring for the hose
The bolt can be reused if you want to
Note: the bolt is removed with a Torx bit (if I figure out the size I’ll post it here)
link with more information
https://www.freel2.com/forum/topic32245.html
Good luck
Paul
Old Feb 5, 2020 | 05:17 AM
INTER911's Avatar
5th Gear
Yes, thanks. Those pictures were helpful. I ordered the hose but not the O ring. There was no separate listing for the O ring for sale so I am hoping it comes with it. So far the illustrious delivery service has only seen fit to leave notes on my door saying I was not home when they attempted delivery even though I was home and waiting after making sure the doorbell worked and got the dog barking when pushed. This is the second time this service has done this to me. Last time was days before I finally got the part.
Old Feb 5, 2020 | 09:28 AM
p_gill's Avatar
Hopefully the o-ring comes with the hose
The part numbers are
LR001442 - Coolant Hose for heat exchanger
LR001505 - O-Ring for heat exchanger hose
LR000491 - Bolt for Heat exchanger hose
i also recommend that you replace the Thermostat they tend to fail every 10 years or so
LR006071 - Thermostat
I created a list of things that should be replaced as our LR2's get older
From that list you are working on
Typical repairs for high mileage 3.2
A) Thermostat – replaced mine at 10 years (also replaced two coolant hoses)
Here is the complete list
https://www.freel2.com/forum/topic32504.html
Good luck
Paul
LR2inColorado
LR2
Jun 5, 2019 09:57 AM
Martimouse55
LR2
Jan 29, 2019 12:13 PM
LaGirl
LR2
16
Jan 17, 2014 07:15 PM
Carl082974
Oct 25, 2010 09:28 PM
