2008 lr2 electronic nightmare
Old Jul 3, 2019 | 12:28 PM
12master's Avatar
3rd Gear
Default 2008 lr2 electronic nightmare
hello,newbie here, but have my 2008 lr2 for about 2 years,no problems,till now! about a week ago I was driving it, when all the lights on the dashboard illuminate at the same time, the temp gauge went all the way up, and hazard lights turned on, at that moment ,the car will not accelerate or react to the gas pedal. I turned the car off, started it again, and everything went back to normal, for about 2 minutes! and all lights come back again and car will not accelerate, also big E on dash, and transmission fault on messages. after repeating this for about 5 times to get back to the house, next day I tried to start the car, and all the dash lights will illuminate again, big E on dash, and will not even atemp to start,..I already try disconecting battery (that is brand new), and reset computer, but nothing changes, and the obd scanner can not communicate with the ecm either! please help with some ideas!!!!!!! thanks
Old Jul 5, 2019 | 12:28 AM
Jade Dockery's Avatar
I’m new too. Is it overheating at all? Not sure if a bad alternator would cause that to happen in the way it did. I’ll keep thinking
Old Jul 5, 2019 | 03:53 PM
12master's Avatar
3rd Gear
is not overheating,does no start at all, and is not the battery or the alternator
Old Jul 5, 2019 | 07:44 PM
ThorInc's Avatar
Check here:
https://landroverforums.com/forum/lr...eltdown-17942/
Old Jul 5, 2019 | 08:03 PM
12master's Avatar
3rd Gear
Originally Posted by ThorInc
Mather of fact,I did read that before posting, and as consequence, I put a. Rand new battery,just for kicks, but made no difference, the car will not even start,has the e on the dash,and the temperature gauge goes all the way up. Tjat is exactly what it was doing when it was drivable, suddenly, all the dash will light up,temperature gauge will go to the top,and will stop accelerating. If at that moment you turn it off,after a few seconds it will start and drive normally,for 2 minutes, and everything will happen again. Also,the navigation will reset about every 3 or 4 minutes. I did see the is a reconfiguration for the body control module,may be that's a fix? Don't know, I'm completely lost,and a land rover mechanic is going to cost a pretty penny,and if is not a expert,is no going to be able to fix it. Thanks for answering!
Old Jul 9, 2019 | 12:29 PM
p_gill's Avatar
Start simple
What is working?
Can you lock an unlock using the key fob? Lock button on the dash?
What works in
- ignition mode 0 (Key docked)
- ignition mode I (Key docked, foot off the brake, press start/stop briefly)
- ignition mode II (Key docked, foot off the brake, press start/stop 2 seconds)
See this link for explanation of ignition modes https://www.freel2.com/forum/topic33506.html
Try to communicated with the ODB II when you get to ignition mode II
Good Luck
Paul
Old Nov 18, 2019 | 03:14 PM
Ibbies's Avatar
Default Update
12master, could you find out what caused this issue. I have the same problem and can't find the cause
Old Nov 18, 2019 | 03:35 PM
p_gill's Avatar
https://www.freel2.com/forum/post137592.html
Old Dec 18, 2019 | 01:37 PM
Ibbies's Avatar
Still can't find out why. Checker central junction box and looks ok. Any update?
Big E in Dashboard where the gear selection is showed
Temp gauge jumping hot / cold /hot /cold
Hazard lights go on
No start
bburson
LR2
Dec 21, 2018 04:21 PM
Carlos Moreno
LR2
Mar 13, 2016 02:17 PM
Rolex
LR2
Sep 4, 2015 03:32 PM
Cap'n Chuck
LR2
Feb 25, 2014 08:10 AM
lin8810
LR2
Sep 7, 2008 07:59 PM
