2008 LR2 running rough after replacing power steering pump
Old Oct 31, 2020 | 02:12 PM
abfoster's Avatar
Question 2008 LR2 running rough after replacing power steering pump
I replaced the tensioner, belt, power steering pump, and idler pully. Once J get it all back together, it won’t idle, it surges when idling and misses when accelerating. I found this and can’t seem to find where it connects and if it is a vacuum hose, etc. If Vaccum, maybe it’s the problem. Any help would be greatly appreciated.
Thanks,
A. B. Foster
What Is and where does it attach?
Old Oct 31, 2020 | 02:35 PM
flybd5's Avatar
I think you mean once you THOUGHT you had it all together... No clue what it is but it does look like something important.
Old Oct 31, 2020 | 02:41 PM
abfoster's Avatar
Funny, yes, once I “thought” I had it all back together.
Old Oct 31, 2020 | 02:56 PM
flybd5's Avatar
If you check the engine error code(s) it might tell you what you took out that it wanted back.
Old Oct 31, 2020 | 04:25 PM
ThorInc's Avatar
From my recollection, that's the auto 6 speed Aisin transmission breather hose; if I get time I will look up the part number.
It's located at the rear DS of the engine against the firewall.
Old Oct 31, 2020 | 07:43 PM
abfoster's Avatar
Makes sense, I found a tube coming off the transmission that looked like it needed something connected to it. I just need to figure out which end connects to it.
Old Oct 31, 2020 | 07:45 PM
abfoster's Avatar
Don’t guess that will cause the engine to surge, huh?
Old Oct 31, 2020 | 08:01 PM
flybd5's Avatar
Coins come in handy right about now.
Old Oct 31, 2020 | 08:19 PM
ThorInc's Avatar
From your pic above, the end on the right of your pic. The other end with the inverted "u" rubber pipe is up & against the firewall.
Old Oct 31, 2020 | 08:21 PM
ThorInc's Avatar
I guess it's possible...........only one way to find out.
Ham803
LR2
Jul 27, 2020 10:54 PM
razorgaze
LR2
16
Jan 26, 2019 06:17 PM
Davecz
LR2
Jan 13, 2018 12:47 PM
